HFC Approved Stripped Cover Plate Hole Fix
Hamerhack
Time for the annual DuoTone battery change.
A couple of the cover plate screw holes are worn, so the screws don't grip.
What do you use? A drop of Elmers? Plastic wood?
Thanks!
3 answers to this question
Fill the hole with Elmer's and stick a toothpick in it. Cut it off flush after the glue dries.
I use cut off matchsticks. They're a little bit easier for me to work with and I've never had a problem with them.
Austin
