Need some cleaning advice pleeb!!
SirDouglas
New member
Supporter
/emoticons/default_biggrin.png
I have this 78 (WAS) white (now is tobacco white) Rickenback 4003 that has an issue... i cant seem to git the nicotine and/or what ever other shit gunk on the body or neck to come off /emoticons/default_biggrin.png ive tried lizard spit, the dunlop 65 , 409..... that orange peel shit.... NOTHING is takin this mess off... when i play the neck after about 15 minutes its like the shit is coming out of the pores and makes my palm stick to the back of the neck... irrataing as hell since the other 3 dont do this..... /emoticons/default_biggrin.png
any ideas will help please.... /emoticons/default_biggrin.png
Danke
Sir Douglas /emoticons/default_rolleyes.gif
Randy /emoticons/default_cool.png
I started to suggest Goo Gone, but isn't that the same thing as "That orange peel shit"?
You may be down to naphtha now. THAT'll get it off. (I believe it will, anyway...)
I hate using naphtha, but sometimes it's the only solution.
Try using a light car finish polisher.
You aply a thin layer to the finish and let it dry.
Then you polish it off. Not only does
it remove scratches & small dents
it will guaranteed remove all
yucky stuff as well. I had a pretty
nasty SS1 that was a pain to clean up,
but with a bottle of some sort from Turtewax it finally
worked.
A lot of things actually soak into the finish surface, they're there for ever... and nitro yellows on it's own... you may not get it all out.
Armitage is correct - it may not be possible to get the yellowing out of a finish, although the naptha will remove the gunk and grime accumulated over years.
Just don't smoke while you're doing that little job, or you'll be like the Flaming Banana man. /emoticons/default_rolleyes.gif
Meguiar's Cleaner Wax. Over and over. The yellowing will not go, but the oxidized top coat of laquer will.
I had a 4003 for a while - don't recall the year. It was in pristine condition. But it had a soft finish on the neck and yes, it did get sticky. I believe that is a "known" issue with some 4003s.
