String Travel: So This Won't Work, Right?
Nathan of Brainfertilizer Fame
This guitar has a roller nut, but the trem probably still won't stay in tune because the strings change direction at the string bar, meaning there will be tension/binding at that point that will keep it from returning to pitch.
Right?
8 answers to this question
Basically, I'm trying to convert a guitar with a 2-point non-locking trem and traditional nut to a Floyd Rose double-locking system. If it had the straight string run, I might go with a roller nut or graphite nut w/ locking tuners. However, the guitar I have has the same string travel (spread path) as the one in the picture.
So I'm going to have to find some way to lock the strings.
Since I don't really want to try to replace the nut, that is probably going to have to be behind-the-nut locks.
Unless anyone has a better idea?
Leave it alone and play one of your thirty locking trem guitars when you need that arrangement?
That is an option, and an attractive one.
This guitar is a crap guitar that I want to learn to work on, to take it from crap to AWESOME.
If I can.
Just an idea; if you got a second hand Fender LSR nut, the one with ball bearings, and widened the string exit channels with a Dremel so as to accommodate the string spread, it might work; seems they only come in 1-11/16 nut width though.
