Sustainblock parts
VECTOR
 Share
You see my friends beautiful Sunburst with a massive issue - wrong parts on the sustainblock bridge. To set the intonation is impossible.  Where can he get the matching parts for its bridge? Thanks for your help/ advice!
Edited by VECTOR
Link to comment
Share on other sites
I don't know if there are any left but I was able to get some from Big Sammy's House O' Gear on Reverb a while back. If not, you might try Mann I think his parts would fit.
MannMade USA Hamer Sustain Block Bridge - Nickel | John Mann's Guitar Vault | Reverb
Edited by Hbom
Big Sammy's has no more
  • Like 3
  • Thanks 2
Link to comment
Contact Mann, IIRC, he made some extra parts when he had his first go round of bridges.
Edited by 0054
  • Like 2
  • Thanks 1
Link to comment
What year is the Sunburst?  If it's '81 or later it may have the narrow string spacing and the Mann saddles won't fit.
**edited to add: Neither will the earlier Hamer saddles, for that matter.
Edited by cynic
  • Like 2
Link to comment
Its a '79 or '80
Link to comment
8 hours ago, VECTOR said:
Its a '79 or '80
 I would definitely measure with a calliper or reach out to Mann on proper fitment...
MannMade USA Hamer Saddles - Black Nickel https://reverb.com/item/32848375-mannmade-usa-hamer-saddles-black-nickel?utm_source=android-app&utm_medium=android-share&utm_campaign=listing&utm_content=32848375
  • Thanks 1
Link to comment
  • 9 months later...
I've been searching for such a long time.
Do the saddles fits to a 1979 Hamer Sunburst?
They look like the originals, but is the dimension right?
Mann's Saddle width is 412" (10.4mm). I’am not sure but my saddles seems to be 10mm.
Thanks a lot for your help.
https://www.johnmannsguitarvault.com/shop/Parts/Guitar-Parts/Guitar-Bridge-Parts/p/MannMade-USA-Hamer-Saddles---Nickel-x47787123.htm
Edited by Frank Neli
Link to comment
The originals are typically 3/8" wide (.375 ± .010). But there was a bit of leeway among several different versions.
I'm a little surprised John's are .412. I think (it's been a long time) the string-thru holes are spaced at .425, so they should work just fine.
  • Like 3
  • Thanks 1
Link to comment
Hmm.  I recently got an old used sustainblock bridge.  I was told it came off an 82 so I assumed narrow.  The string spacing is 2.00 inches but the saddles Are wide.   They measure out at .410 and won’t center over the holes.  Is this normal or did somebody mix and match and some point?
Edited by Ua D
Link to comment
My '81 Special (w/it's original Sustain Block) has the spacing for the string-thru holes at .400 (thanks, Steve!) and the intonation screw holes at .375, making the string-thru holes progressively nearer the outside of the saddle thru holes. It's not much but it is odd to see it done like that.
Hamer used at least 3 different saddle types and probably as many Sustain Block varieties (I don't think they believed in tolerances back then, from what I've seen :lol: ), but I can't imagine what you have there was born that way. That looks AFU even by early Hamer standards!
Link to comment
I assumed they kept the through-hole spacing at 0.400 to allow room for the ferrules on the back (they can be pretty tight at 0.400) but reduced the measurement between the intonation holes to achieve a desired saddle spacing.
Link to comment
 Share
