Retractable Hand Cart
Ted
New member
Are there any good products in the form of a Retractable Hand Cart for moving amps, speakers, other gear out there?
I just turned 42 and after having a really bad accident in '04 I can't lift/move the good ole 70lbs and up Tube amps/speakers/4x12 Cabinets/etc. anymore.
I've got something similar to this:
I picked it up at home depot for like $50 6 or 7 years ago. Not sure what the weight limit is, but it folds flat and will easily move a PA cab/small combo. No way it's moving a 4x12 though. There may be a more heavy duty one but probably won't be as portable. Downsizing will help your back too!
Rock N Roller carts work well. Get the smallest one.
Thanks so much again Elduave!
The guys and girls on the HFC are truly the best group of people I've met in cyberland!!!!!!!!!!!!!!!!!
Hey Silentman,
I'm going to need a heavier load capacity, but Thanks once again!
I bought one like this at Costco within the last year -- bent the crap out of the aluminum handle the first time I used it carry a Marshall 4x10 cab. Handle isn't strong enough for a heavy amp or cab.
More great information! I guess that's why it is said, "Knowledge literally is Power--Relating to torque and other physical forces and stresses"!!!!!!!!!!!!!!!!!!!
I just bought one at Costco a few months ago. Haven't tried to move any gear yet but I got rid of my 4x12s years ago.
I bought one that's similar to that one pictured.
Got it over 10 years ago for $100 and it's still going strong.
I've used it for some really heavy stuff (marble dining room table, amp racks, 15" speaker cabinets etc.).
I bought it at Sam Ash.
I'll find out the name and model and post it.
This is the same one I use.
Made by Wesco.
I've used it for everything heavy and it's been with me for 10 years now.
It's lightweight and compact and can handle the abuse.
Link:
http://www.markertek.com/Furniture-Storage...nc/220617.xhtml
I use both the Wesco and the RNR R-12.
The R-10 above is good for hauling lots of heavy gear on pavement.
It's a lot heavier than the Wesco, costs more, and takes up more space.
But, it holds more and is adjustable in length, it can be many carts in one.
It's also built like a tank and will last a long time.
So they both have there + and - sides.
I use both for different things and would recommend either one.
I was in one band that had a roadie and a soundman.
The roadie was worth every penny.
The soundguy wasn't.
Seems like a bad idea to be using a 4x12 if you have a bad back, regardless of the gear hauling equipment you might have. You still have to get it in and out of the car and up and down stairs and stages.
Another option would be to switch to several 1-12" cabinets using lightweight speakers and wood.
I have roadies.
Roadies would be nice! Maybe someday.
Yeah, Don't know what to do with the 4x12. Hard to sell it without getting very little for it.
I've got one like this and it will move a 4x12. It's got a weight limit of 250 lbs or so.
Ted, I use a similar model called the Ruxxac XL that I bought about 9 years ago. It's my go-to cart for load-in and load-out. It's handled my entire bass rig (3x10 Cab, Amp, and Misc stuff bag) in one trip many times. Good stuff.
For a selection, go here. I use the Magna Cart for schlepping various things around, but I haven't used it for really heavy cabs and amps. It's only about $21 at Costco and Sam's. For amp hauling, check out the Wesco Maxi with 250 lb. capacity or the much more expensive Mega with 550 lb. rating.
