Dumo Posted November 21, 2008 Posted November 21, 2008 Like new in the box with adapter. Original receipt for $189.99. Awesome Marshall stack tones. Very versatile EQ system. Asking $110 shipped in the CONUS. Thanks. Radial Tonebone Hot British Features: * LEVEL control: Used to balance the output level between the input drive without altering any of the tonal characteristics. Works somewhat like a master volume on an amplifier. * HIGH & LOW controls: Post distortion active tone controls that boost or cut from 12 o'clock position. Low: +/- 14.5 db @ 100Hz; High: +/- 10 db @ 4.3kHz. * CONTOUR control: Used in conjunction with the VOICING selector switch, the passive contour control dials in the mid-center frequency for either cut in the V' position or boost in the FAT position. * DRIVE control: Used in conjunction with the drive gain switch, drive is used to adjust the overall amount of gain to the overdrive circuit. * TOP END switch: Switch sets the overall tonal character of the Hot British to best match the amp and it's settings. Brighter amps are normally compensated with darker settings. Bright: Boosts +6dB @ 10kHz; Flat: No boost; Dark: Cuts -6dB @ 1.8kHz. * VOICING switch: Three position switch allows the user to jump to chunky V style scooped rhythms or huge solos in the FAT position. Fat: Mid boost - passive filter; Bypass: Flat Scooped: Mid cut - passive filer. * MID BOOST switch: Used to fatten up the sound for more cut and sustain during solos. Also, will fatten up the sound of single coil pick-ups. High: Boosts +12dB @ 620Hz; Medium: Boosts +6dB @ 390Hz; Bypass: No boost. * Tube: Standard 12AX7 vacuum tube inside is used in distortion stage to accentuate upper harmonics and warmth. * Distortion: Proprietary tube hybrid distortion circuit. Wide range of distortion settings may be derived. * Footswitch: True by-pass with red in/out status LED. * Power Supply: 15VDC adapter (110V standard - export models available). * Construction: 14 gauge steel construction with baked enamel coat. * Standard package: Includes power supply, rubber stick-on feet, owner's manual.
harry65 Posted November 21, 2008 Posted November 21, 2008 don't know if you're interested but how bout a swap of tube driven pedals just for shits and giggles, i have an older usa made tube works real tube(butler designed) with the three band eq, currently has a nos 12ay7 in it but i can put anything in it like a jj 12ax7, be cool, harry......................
Dumo Posted November 21, 2008 Author Posted November 21, 2008 Hey Harry, I'm looking for cash mostly unless you have a Wampler Pinnacle II for trade. This might be sold off my local Craigslist anyway but you know how that goes...
