robberns Posted June 19, 2012 Posted June 19, 2012 For those who love that "Class A" sound of a cranked Vox AC-30, Wampler has developed an overdrive pedal that will get that tonality that they love so much. It is Wampler's take on the "Brian May Tone", but it really is capable of ALOT more than that as well. With the gain set at 12:00 or less, it has a brighter "top boost" quality that the many identify with that Class A tone. It's very pick responsive yet stacks well with other overdrives. Excellent condition, no velcro on the bottom. $110 shipped in the CONUS. Specs: • High grade film capacitors and resistors picked for their superior sound and response • True bypass • Accurate "Brian May" type tone, think "Fat Bottom Girls" tone • Multi-color LED • Small box size (roughly the size of a boss pedal) • Very pick responsive - play light and it's clean, dig into the strings and it gets nice and dirty • Not a clone of any previous circuit unlike so many others! • Very light overdrive all the way to near fuzz-like when at max settings • Sounds great with a tube OR solid state amp • Sounds great at low OR high volumes • Battery connection and 9v power jack (barrel plug like Boss)
robberns Posted June 19, 2012 Author Posted June 19, 2012 2-channel Overdrive pedal with a 12AU7 tube inside. Separate EQ for both channels, experiment with different tubes (12AX7's, 12AT7's, etc...) for different levels and flavors of overdrive. Does not include an AC adapter, but any Boss-type will work. $125 shipped in the CONUS. "Double the drive with the new Duel Overdrive pedal. With two overdrive circuits based on our own Big Ben Overdrive pedal, the Duel Overdrive provides foot switchable access to two sounds from a trunk-full of classic and modern tones. With separate Gain, Volume and Tone controls, you can set the pedal up with two totally independent overdrive sounds (aptly named OD1 and OD2!) to compliment a clean-bypassed tone. To make it even more flexible, we've added an assignable (OD1/OD2/both) low-end bass boost function for fat-bottomed overdrive tones. Add the Duel Overdrive to your existing pedal setup and benefit from an unmistakably “real” valve overdrive." • Duel Overdrive CT07 ◦ Connection: Input: x1 (guitar input), Output: x1 (line output) ◦ Controls: Gain, Tone, Volume, Bass boost ◦ Tube: 12AU7 ◦ Power: 4 x AA batteries (allows 16 hours of operation) ◦ Dimensions: 1 6.84 cm (6.63”) (W) x 15.55cm (6.12”) (H) x 6.4cm (2.52”) (D) ◦ Options: 9V AC adapter
gtone Posted June 20, 2012 Posted June 20, 2012 I have the Cooltron VibraVox trem/vibe pedal - sounds very warm and organic w/the 12AU7 tube. It's feature-set works a charm and is pretty trick, too. Only thing I don't really dig is it's size, but it's not a deal-breaker for me, especially when you fire up the beast. Good luck with your sale robberns!
