alpep Posted August 20, 2007 Posted August 20, 2007 took in a pile of stuff over the past few weeks and I am looking to purge some old to make way for the new. Interesting trades welcome. peavey m 3000 power amp. stable reliable peavey goodness $150Pryamid pa600x power ampSpeaker Switch: The PA-600X features a switchable speaker option. By depressing speaker switch A the speakers on channel A will become operational. Speaker switch B operates speakers hooked up to channel B. For full stereo operation both switches should be depressed. Output Level Gain Controls: There are 2 separate output level gain controls. The left knob controls the gain level of amplifier channel A and the right gain level controls channel B. The unit can be rack mounted or table top mounted. The PA-600X has built-in pure aluminum heatsinks to help dissipate heat build up from the integrated circuits inside. Specs Continuous Power Output (both channels driven): 20 Hz to 20 KHz: 300 watts per channel (8 ohms) 1 KHz: 600 watts per channel (4 ohms) Total Harmonic Distortion: 0.1% at rated power (8 ohms) Frequency Response: 10 Hz to 50 KHz ± 3dB Input Sensitivity: 1 Volt for 70 watts at 8 ohms Input Impedance: 47 Kohms Signal to Noise Ratio: 90dB (A-weighted) Speaker Impedance: A, B, A + B (4 - 16 ohms) Power Requirement: AC 115V / 230V switchable Power Fuse: 6A / 115V or 3A / 230V Dimensions: 480(W) × 100(H) × 273(D) mm $125Carvin dcm1000 1000 watt power ampDCM1000 Power Amp1000W bridged 4 ohms, 700W bridged 8 ohms. • Continuous RMS per CH: 8 ohms 225w, 4 ohms 300w, 2 ohms 500w. • Not rated "pulse power" or at 2 ohms for a few minutes like some amps • THD 20-20kHz @ rated 90% output: 0.1%, 50% ouput 0.03%. • High transparent 45v/us slew rate. Studio quality 100 dB S/N ratio. • INPUTS: 1/4" balanced and female XLR balanced. • OUTPUTS: 5-way binding post, Speakon™ and two 1/4". • Switches: limiters, ground lift, paralleling inputs, bridge mode. • Recessed level attenuators, clip, signal, protect and power on indicators. • Soft-start, DC SpeakerGuard™, thermal and short circuit protection relays. • Variable speed fan. Heavy-duty all steel construction. • Dynamic low frequency punch with transparent high-end for uncolored sound. • 2U rackmount 3.5"H x 10"D x 19"W, WT: 25 lbs. excellent condition lots of bang for the buck. $250phase liner 400 yup you know what these are it works great and is in excellent condition. ONe of the best sounding solid state hi fi amps I know. $250wood cabinet for the phase linear 400 700b or 4000good condition some minor scratches and dings $85phase linear model 5100 series two digital synthesized tuner. I should keep this but I have too much stuff. $150Phase linear turntable $150Dynaco ST 150 classic made in Blackwood NJ hi fi power amp. Wood sides some minor scratcher etc. 75 watts per channel $175Phase liner 4000 series two peramp. great classic hi fi sound.$200harman kardon hk 300xm cassette player $40harmon kardon linear tracking turntable. Not sure if I want to let this go. catch me in a weak momentbsr real time spectrum analyser model sa-3x $50asr systems parametric octave band eq eq-10 it works $50e me at alpep@lostartvintage.com if you have any interest or have something to swapthanks
alpep Posted August 21, 2007 Author Posted August 21, 2007 phase linear power amp, preamp and wood cabs are gone. I have another phase 400 if anyone is interested. I may decide to part with it. also for those who know something about reparis peavey 1.5 power amp huge thing DOA $100 as is heavyearly crest amp channel A is ouit (or it is set in perpetual bridged mode)475 watts per channel $200 as is
