FA: MIJ Fender '52 Reissue Telecaster PARTS Micawber - 99 cents...
Got a Tele neck burning a hole in your pocket? Selling MOST of a 1994 Made in Japan '52 Reissue Telecaster on ebay -- opening bid is 99 cents, NO reserve! Rare factory Micawber style -- factory routed for a humbucker in the rhythm position. Check it out here...
Nice. How many pieces is the top, and do you have a weight??
Thanks, bobbymack!
The body appears to be made from 3 pieces of wood. MOST of the body is one piece -- from the left side all the way across to the right side of the control cavity. You'd be hard pressed to see this seam from the front or the back unless you're looking for it -- it matches very well with the main body. Then, there's another piece that picks up from the right side of the control cavity through the entire rest of the guitar -- EXCEPT -- one last piece (thin, about 1/4" at its widest, and about 3-1/2" long) right next to the output jack cup. This piece doesn't match as well, but it's small. See photo below for approximate locations of seams.
Weight is 5.4 pounds fully loaded with everything in the photo.
Lemme know if you've got any other questions...
