santellavision Posted July 23, 2022 Posted July 23, 2022 Hughes and Kettner Grandmeister 40 Amplifier Head Latest version. 40 watts. 4-channels. All-tube EL84 Power and 12AX7 Preamp. Near-mint condition. Works perfectly – no issues. This is an all-tube signal path, just with digital control over the presets! The absolutely perfect amp for cover bands. With 128 presets and 4 different preamp circuits plus EFX, all at your feet, you can cover anything! To quickly explain… You can instantly recall 128 presets. Go from a warm, Blackface clean w/Reverb to Slightly Dirty Dry Clean w/Chorus, right to Marshall Crunch, then to another even Dirtier Crunch w/Flange to Screaming Lead w/Delay! Instantly with no lag or channel popping noises. All analog, no modeling funkiness. Front panel setting for Gain, Volume, Tone, EFX, Resonance, Presence, EFX loop and Noise Gate are all saved in each preset! Loaded with 4 new JJ EL84 Power Tubes. EH 12AX7 Preamp tubes. Ready-to-go. The amp features: - 4 channels with different preamp circuits on the front panel - Clean to Metal - Boost on all channels - Delay - Chorus - Flange - Tremolo - Spring Reverb - Noise Gate - REDBOX Speaker Cab Sim with XLR output - 40/20/5/1/0 Power Soak The key to letting this amp sing is to use a simple MIDI pedal. You can preset 128 tones and call them up instantly with no lag. No fancy MIDI programming required. Just save your amp settings to program change 1-128, that’s it. And easily tweak and re-store your settings right on the front panel with the Save button to the preset your on! I’m no MIDI genius by any means, and I saved my presets in seconds. Message me if you have any questions. Comes with optional WM-1 interface WiFi adapter ($200) for even deeper iPad programming and storage of presets. $1,000. Shipped PPG including WM1 interface adapter. Not interested in any trades on this one-thx NOW, includes the 8-button Melo Audio MIDI footswitch. Perfect for this amp.
GuitarGuy65 Posted July 23, 2022 Posted July 23, 2022 GLWS Ernie! I've got one of these too and it's a killer amp that is ultra-versatile and provides incredible bang-for-the-buck... I run mine thru a 2x12 vertical cab with Neo Creambacks and it sounds amazing! 😎
santellavision Posted July 26, 2022 Author Posted July 26, 2022 How about I throw in the Melo Audio Commander programmable MIDI Foot-switch and cable. ($150. value) Great size, easily fits on pedalboards. This lets the Grandmeister rock with 8 instant amp presets buttons and 128 programmable patches using the up/down bank buttons. Plus, two expression pedal inputs. https://bit.ly/3OzTr3t
