My baby needs a new sound system (NHC)
First up...
Focustite Trakmaster Pro: I have 2 of these, racked but never really used. Buy em both fot a great stereo mix!!
$400 for both + shipping
Key Features
Award-winning Class A discrete transistor-based Focusrite pre-amps
This pre-amp demonstrates the same wide bandwidth philosophy featured in the original vintage Focusrite units, ensuring low noise and distortion.
'Pro Series' Latency-free monitoring
Monitor your source signals within the mix, directly at source, avoiding having to resort to monitoring via your DAW or digital desk, both of which may be prone to latency issues.
Custom Opto Compression
With the addition of variable attack and the unique ‘Squash’ mode (ideal for intense drum sounds), this compressor gets you the compression sound you need in seconds.
Optional Stereo 24 bit / 96kHz ADC
Tracking a vocal direct into your DAW or any other digital recording media has never been easier or more affordable. The Platinum Pro ADC provides a stereo digital S/PDIF audio output and can be retro-fitted at any time.
Switchable impedance
The Low Impedance switch brings yet further sound options to your recording, allowing you to get more from your microphone and make the most of ribbon mics, which perform best when combined with a low impedance preamp.
Front Panel Direct Instrument Input
For quick and easy connection without the need for a separate DI box. A High Gain switch provides the option to boost the incoming signal by 20dB - ideal for passive guitars.
Mid Scoop EQ
The Mid-scoop EQ is a quick and effective problem-solver. With two different depths of cut and an adjustable frequency control, it’s ideal for vocal problem solving or for creating great miked-up cabinet ambience.
More to come!!
How do those pre's sound on heavy multi tracked guitars?
Atually I really wouldn't know... I also bought a Vocalmaster Pro at the same time and only used that once or twice. The Pre's for sale are basically never used. I'm sure their decent.
  • 3 weeks later...
