Audio Experts,need 3" full range speakers
singlehum
Looking for some help from the audio experts here. I need to find a pair of 3" full-range speakers (4 ohm, 25 or 30 watt) for a project, preferably that will tolerate moisture (marine speakers?). Anyone know where I could source these? Thanks.
2 answers to this question
For starters, avoid anything with a paper cone; polypropylene or aluminum would be preferred. These cones will hold up against moisture but aren't waterproof. Here are the PartsExpress candidates with non-paper cones and 4-ohm impedance. Then there's Madisound, That's a list of all their 3" full-rangers, so you'd have to sort through for non-paper, 4-ohm models.
One that's sure to meet your needs (waterproof, 4 ohms) is the Aquatic AV AQ-SPK-3.0 at $26 each. As the brand-name implies, these are designed and built for aquatic duty.
Since the Aquatic AV 3-incher's bass response stops at 120 Hz, you might want to consider one of their marine subwoofers to add an octave to the bottom.
