Travis Posted April 18, 2005 Posted April 18, 2005 Looking for a flat top rear routed project body. No archtops or elbow contours, bevels are fine. I'm thinking a bolt on would be easiest, but if someone has a neck through or set neck that fits the description, we can talk. Bridge style is not important, neither is pickup arrangement as long as it has a HB in the bridge. Let me know what you've got. Thanks
serial Posted April 18, 2005 Posted April 18, 2005 I've got a Tele shaped body. Only routed on top for a Tele bridge pickup and neck pocket, control cavity is rear routed. No bridge or control holes or neck screw holes routed yet. A clean slate. No finish, nicely done. Email me if interested.I know you're looking for a hum routed one, but I suppose that is possible with this one. Two piece alder IIRC.
serial Posted April 18, 2005 Posted April 18, 2005 Oh crap, I forgot that I also have a korina SG blank body-no routes at all yet. I've got too many projects, so lemme know if you'd be into either one.
Travis Posted April 18, 2005 Author Posted April 18, 2005 Unfortunately I don't have access to anything with which to route a body. I should have said that a pre-routed body was a requirement. I appreciate the offers, though.
serial Posted April 18, 2005 Posted April 18, 2005 The Tele IS routed. The only thing that isn't there is the neck screw holes (a drill can do) and holes for the pot shafts and jack (again-a drill can accomplish these).
