Rich_S Posted October 23, 2013 Posted October 23, 2013 My Slammer Series Sunburst has a flush-mount output jack, which is getting kinda wonky. I assume this is a replacement for it:http://www.stewmac.com/shop/Electronics,_pickups/Components:_Jacks/Flush-mount_Output_Jack.htmlStewmac's version doesn't get very good reviews; people say it doesn't last very long. Are there any better-quality versions available elsewhere that will last longer, but still fit Hamer's 1/2" hole?As a hardcore Tele guy, I think the Electrosocket jack cup with a Switchcraft jack is about the best mounting system out there, better than this thing, better than a Les Paul's surface-mount plate. However, I foresee failure and misery would result from any attmept to enlarge the 1/2" hole to the 7/8" an Electrosocket requires. The only sure-fire way to do it would be to plug the hole first, then re-drill it with a 7/8" bit. Way to much trouble for a cheap guitar.Unless some one has a higher-quality alternative, I guess I'll just use Stewmac's jack and buy a spare.
murkat Posted October 23, 2013 Posted October 23, 2013 " the Electrosocket jack cup with a Switchcraft jack is about the best mounting system out there," For side mount ,Yup. unless it is the cool factored hidden strat side mount input jack assembly
HSB0531 Posted October 23, 2013 Posted October 23, 2013 That's because it isn't Switchcraft. That one is made in Japan, and it's a Tip Ring Sleeve design. The correct original part is a Switchcraft Model 151 thick panel mount jack. You want this one: http://switchcraft.com/Drawings/151_cd.pdf http://www.markertek.com/Connectors-Adapters/Audio-Connectors/1-4in-Phone-Connectors/Switchcraft-Corporation/SW151.xhtml
Rich_S Posted October 23, 2013 Author Posted October 23, 2013 Switchcraft 151... cool, that's what I needed to know. Bookmarked.
Rich_S Posted October 24, 2013 Author Posted October 24, 2013 It's like a Hamer, but it's for guys with four kids to put through college.
