PastorPaul Posted June 3, 2008 Posted June 3, 2008 THIS IS TO CORRECT AN ERROR in my original post. I made a dumb mistake, thinking Daytona.I've got a black brushed metal control cavity cover for a Special, Studio, etc. that I don't need. Any interest? I'm moving and have a bunch of parts to get rid of.I also have a pair of black covered P90's from a USA Special for sale. I bought them on the HFC last year, but abandoned the project for which I was going to use them.
Thundernotes Posted June 3, 2008 Posted June 3, 2008 If that rear cover will fit my Diablo, I'll take it PM Sent
PastorPaul Posted June 3, 2008 Author Posted June 3, 2008 If that rear cover will fit my Diablo, I'll take it PM Sent I don't know if it fits other bodies, e.g. the Diablo. Might be a question for Kim Keller.
cmatthes Posted June 3, 2008 Posted June 3, 2008 I don't believe it does. The Daytona plate has a small extension that goes under the trem bar: The Diablo should be a thinner rectangle. Brian - did you ever get the ones I sent you? (BTW - Kim is on vacation this week)
Thundernotes Posted June 3, 2008 Posted June 3, 2008 Nope, nevermind - I was envisioning the triangle-shaped cover. I did get the second trem-cavity cover you sent Chris. All set there. I'll check with Kim about the Diablo cavity cover. Hopefully he can help out. Unless someone else here has a Diablo control-cavity cover..... ...........
silentman Posted June 3, 2008 Posted June 3, 2008 Brian, if you can't source a part, check out www.fretsonthenet.com He can make you what you need and is reasonable.
