I have a Hamer that a previous owner had changed the knobs on. When I decided to change them to the proper 'top hat' types, I found that one of the 'lugs' on the shaft of the control had been broken off before I bought the guitar...these are the things on the end of the shaft that you can re-tension to keep the knobs from falling off. The control works fine otherwise. Can a new 'lug' be soldered on?
Also, out of curiosity, has Hamer USA guitars used the same volume and tone pots since the beginning? Are they all specially made specifically to Hamer's specs, and are there no equivalent commercial replacements? What are the specs and how do they differ from other commercial pots? If I need a replacement for a USA Hamer, who do I need to contact?
crunchee
TIA!
2 answers to this question
