Case for newport
Will1965
Hello,
I'm looking for a case for my Newport with bigsby.
Does anyone know if a case for a ES 335 fits?
Any other cheap alternatives?
Cheers Will
3 answers to this question
The Newport is not a common size. A 335 is significantly bigger and a Newport deserves better than to rattle around in an ill-fitting case.
You might check out this.
Gibson has made several downsized semihollow thinlines through the years, such as the ES-336 and the Johnny A. Currently they make one called the ES-339. And as it happens, Musicians Friend has the ES-339 hardshell case on sale here. The ES-339 is about 14" wide, so measure your Newport to see if it's about the same.
What are the upper and lower bout measurements on a Newport? I can measure my Howard Roberts case when I get home if you like.
A Howard Roberts case may be about as difficult to locate as a Newport case, but if it works it would give you another alternative as you look.
Thanks for the info guys.
Will check the dimensions.
Thanks for the info, I live in the netherlands so the case at Musicians friend is no option.
Cheers Will
