Hello, I have a Hamer Slammer Series Daytona - (Korea). The top tone pot for neck pu is not working. Here is a link for a short video that I took testing the pu's. Hopefully the volume is loud enough to hear the humming. Is this "normal" humming? I realize that when the switch is in the 2nd position - it cancels out the major hum, leaving only a slight higher pitched hum. Would that higher pitched hum indicate a grounding issue?
I do realize that the top tone knob is for the neck pu and bottom tone knob is for the middle pu.
As for the top tone pot not working - I don't see any wires disconnected, and when I checked for resistance, the readings indicated the same as the bottom pot that does work - unless I'm doing something wrong. Hopefully, the video might help with any suggestions or help you can offer. Thank you in advance!!
bobbycheetah
https://www.dropbox.com/s/7lv38t0ai7dkn47/guitar-buzz.mov?dl=0
16 answers to this question
