When the regulator specifies no more than 15V over, are they referring to the secondary output of the Transformer? 15V out of the rectifier would be good for a maximum transformer voltage of 15 +15= 30V? Going over is a thermal load on the rectifier it can not handle?
Anyone know where I can get either an all-in-one solution or a 15V version of the regulator above?
JGale
I need 15v 2amp regulated DC.
I am having of a problem when I try to Goggle low voltage DC power supplies. Too much stuff and insufficient EE knowledge to discern the difference.
So, here is my solution question.
https://www.antekinc.com/an-0120-10va-20v-transformer is a 20V output stepdown transformer.
https://www.antekinc.com/dr-12b-12v-2a-regulator-module/ is a 2A 12V rectifier/regulator. It would be better if it was 15V. The questions arising out of all this is:
TIA
It's to power this amp https://londonpower.com/electronics/micro-cigar-box-amp/
12.6V may be the best I can do. This is nice all-in-one solution: https://glass-ware.stores.yahoo.net/trps1.html
Trying to avoid switching power supplies (SMPS).
Edited by JGaleLink to comment
Share on other sites
3 answers to this question
