morningstar Posted March 6, 2011 Posted March 6, 2011 I have a Centaura USA neck with a FR nut and Schaller tuners, and a Rio Big Bottom Bastard Set.I am trolling for a USA Diablo Body, either I or II is fine.Can the Rio P-90's be wired to stacked concentric pots for tone and volume? Either way what are the best pots (within reason)?Can I use the Tele style "hat" three way in a USA body?The jack plate, if missing... do any modern products fit?Thanksmorningstar
Jem Posted March 7, 2011 Posted March 7, 2011 I have a Centaura USA neck with a FR nut and Schaller tuners, and a Rio Big Bottom Bastard Set.I am trolling for a USA Diablo Body, either I or II is fine.Can the Rio P-90's be wired to stacked concentric pots for tone and volume? Either way what are the best pots (within reason)?Can I use the Tele style "hat" three way in a USA body?The jack plate, if missing... do any modern products fit?ThanksmorningstarCTS pots are a bit of a no brainer - industry standard and not expensive.Some far east 3 way blades aren't the same screw spacing so use CRL or Oak - both fit although i can't guarantee that top hat toggle will stay on due to the switch being surface mounted.Jack plate is standard strat.
Thundernotes Posted March 7, 2011 Posted March 7, 2011 Hope you find all the parts! When you finish it, the result will be a very nice guitar. Here's the one I built last month:
morningstar Posted March 8, 2011 Author Posted March 8, 2011 Thanks guys GAA GAA that Centiablo calls to me. drooollll.morningstar
Jimbilly Posted March 8, 2011 Posted March 8, 2011 Can you get either of the local shops (Warmoth or USA Custom) to do a Centaura II body?, - 2 reverse hums (p90s in your case) - as I'm sure you remember. Or, let me throw this idea out: A TLE style body, but with the 2 reverse slant p90s?
morningstar Posted March 8, 2011 Author Posted March 8, 2011 I priced Warmoth and I just don't have the budget for a new body.thanks!morningstar
morningstar
Thanks
morningstar
5 answers to this question
