1) guitar is so quiet that only with 100-watt amp turned up to 9 can you hear anything at all (ears would bleed at that volume with any other guitar), and it is still quiet. So pickups are working, but at like 1% volume.
What's the most likely problem? What's the easiest way to determine? What's the fix?
2) If you touch just one of the pots (volume, I think), it crackles and cuts out. Pushing the pot to one side 4-5 times usually results in having the sound stay on...unless you accidentally bump it.
I assume the problem is the wiring connection. So if I re-solder the wires to the pot, should that take care of it? If I do that and there is no change, is the problem the wire or the pot itself? How do I know?
3) Same thing, but at the input jack.
I assume the problem is the wiring connection. So if I re-solder the wires to the jack, should that take care of it? If I do that and there is no change, is the problem the wire or the jack itself? Or is the problem just that I need to clean the jack contacts? How do I know?
Nathan of Brainfertilizer Fame
8 answers to this question
