Attention Vinyl Lovers: Phono Cartridge Recommendation
JohnnyB
There is a high end cartridge maker in Japan named Shelter. They specialize in high end low output moving coil cartridges that range from $1295 to $4900. Taking pity on us peons, Shelter also offers a high output moving magnet cartridge called the Shelter 201. This lowly simple overachiever has caught the ears of the high end audio press. The Absolute Sound has awarded the 201 the Product of the Year for 2015 and an Editor's Choice award for 2016. The retail in the USA from authorized vendors is $310. However, you can pick up this gem from Japanese eBay vendors for a mere $167 or so. Although the 201 bears a striking resemblance to the $129 Sumiko Pearl, they are definitely different cartridges. Check the angle and thickness of the stylus and cantilever of the two models. The Shelter has a longer and thinner cantilever and tinier stylus. These translate to faster transient response and better detail retrieval. Based on its performance, I suspect that its magnetic structure and coil windings are different and better as well. Unlike typical high performance moving magnet cartridges, somehow the 201 exhibits none of that inductance-induced high treble rise and glare.
Sure, they use the same cartridge body, probably mass-produced by a third party, but that's where the similarity ends. It's not that the Pearl is a bad cartridge for $129; it's just that for $310, and especially for $167, the Shelter 210 is phenomenal.
I took delivery on my Shelter 201 a week ago. I've spent a lot of time breaking it in and getting a handle on its strengths and weaknesses. I have played a wide variety of recordings with it--large orchestral spectalculars, intimate voice and piano, solo Debussy classical piano, Baroque ensembles, Eddy Arnold Nashville country, acoustic bluegrass, Miles Davis Kind of Blue, Diana Krall with jazz trio, Tony Bennett with jazz ensembles, Frank Sinatra with Nelson Riddle, direct-to-disk big band, small group jazz,1960s Al Hirt, Dire Straits, The Doors, Vaughan Williams 20th Century British impressionistic/romantic, and on and on. Like I said, everything I could throw at it in a week. Tomorrow I'll try some Billy Idol/Steve Stevens to make sure it handles everything.
Everything I've played on it sounds like the cartridge was designed for that kind of music. That's a pretty good indicator that it's extremely linear. If there were colorations, some genres would excel and others would suck. So far nothing has sucked and everything has sounded captivating and involving. It's the fifth cartridge I've owned since getting into vinyl 9 years ago and it really impresses me. In addition to its timbral accuracy, it's addictively dynamic with an impressive 3D soundstage and imaging.
I think just about every vinyl enthusiast should own a Shelter 201 and here's why:
For those who are accustomed to low output moving coil cartridges that cost 4 figures and above, there comes a time when you have to send the cartridge to a microscopic specialist to put a new stylus on the cantilever. This is expensive and can take months. I often see posts from such owners asking for advice on what inexpensive cartidge to buy to see them through the dry spell. The Shelter 201 should be the one. Some of these users are also frustrated by the noise levels they get from their expensive tube phono stages when trying to add so much gain to cartridges with an output of .02mV.
The Shelter 201 has an output of at least 4.0mV. When I slipped it into my system I had to dial the gain w-a-a-y down to get the volume in line. And when I did, the noise floor dropped like a stone. This in turn improved the dynamic range, and my big band and orchestral showpiece spectaculars had peaks and crescendos that knocked me around the room. This cartridge is dynamic yet smooth, with very realistic timbres, great timing and rhythm--pretty much anything you could ask for.
Now, if you're a low-budget schlub this cartridge is for you, too. Any decent entry-level cartridge is going to run $100-129 or so. And while the official retail of the Shelter 201 is a fairly stiff jump to $310, at $167 for a grey market unit it's a reasonable step up, especially considering what a step up it is in performance. It's also inexpensive to own. My Audio Technica AT150MLX retails around $339 to $499. The replacement stylus ranges from $258 to $325. The replacement stylus for the Shelter 201 is $100--even from authorized US dealers.
So there you have it: excellent tracker, comprehensive truth of timbre, excellent sense of timing and rhythm, very dynamic. available for $167 and stylus replaceable for $100. Most important, very musically involving and satisfying on pretty much any music you play with it. What's not to like?
3 hours ago, JohnnyB said:
Man, those are really good prices for retips. Over here I get the sense that a retip costs about 70-80% of the retail price of the cartridge. I assume these quotes are for nude stylii?
Don't know if its for a nude styli. Have to ask before I order.
It probably is a nude stylus. Nude mounting is a premium feature, but then, your Ortofon is an upscale cartridge. Still, it's smart to ask first.
I finally dug out the box to my phono cartridge.
It's an Audio Technica AT449ML/OCC dual moving magnet cartridge.
FR: 5-30kHz.
Output:: 5v.
Ch. separation: 30dB..
Ch. balance: 0.75 dB.
Maybe I don't need a new one just yet.
FR: 5-30kHz.
Output:: 5v.
Did you mean AT440ML/OCC? The current versions are the AT440MLa and AT440MLb, and they also has internal OCC wiring. My #1 cart since 2008 has mostly been the AT150MLX, which has a diecast metal housing instead of plastic. They both use dual magnets, OCC wiring for the coils, and a MicroLine stylus (the ML part).
Here are an AT440MLb and AT150MLX side by side (and the 440 upside down):
1 hour ago, HSB0531 said:
Yes, the 440.
Good catch
This replacement stylus would probably work for your AT440 if you're interested. Call the vendor to make sure. If you have 4 yrs or more use of that stylus you might consider it.
