Replacement pickup toggle switch for Hamer Artist Custom? (UK based)
bisonkills
Hey folks. After many years of use, the toggle switch in this guitar is getting a bit unreliable. Have done the usual bending back of the metal blades, which solves this temporarily, but it always goes funny again.
Can anyone recommend a like for like replacement part? Switchcraft maybe? This looks about right, but is maybe shorter? Any advice welcome!
165021924_830605444473025_3927049497285428658_n.jpg?_nc_cat=100&ccb=1-3&_nc_sid=f79d6e&_nc_ohc=cyD0sow_N5AAX9x0V8h&_nc_ad=z-m&_nc_cid=0&_nc_ht=scontent.xx&tp=7&oh=9a617a58692dacfcda7580916b2bd563&oe=608313B6
6 answers to this question
Have you tried spraying deoxit and cleaning the contacts with piece of paper between the contacts?... I would do that before replacing
I just fixed one on a PRS in my shop five minutes ago using Murkat's shared trick ... a sliver of 1000 grit wet/dry pinched between the contact blades and gently pulled through to clean the contact point. Flip the paper over, do it again to clean the other blade/leaf. Then do it on the toggle's other side's blades. Takes 20 seconds on a right angle toggle like the one pictured above. You don't even have to remove the toggle to do it.
I'll give this a try. But the switch is over 15 years old, and I think it may be due a replacement. Any advice on the correct part would be useful.
Switchcraft right angle toggle.
FWIW, it's a Switchcraft  3-way for a Rickenbacker - longer threaded shaft, longer knob, such as the one here. Same style as used in my Studio.
Consider @Dave Scepter's advice. My '93 Studio's switch was noisy; a squirt of Deoxit on each contact pair, and drawing a strip of bond paper through the closed contacts, fixed it.
