bubs_42 Posted May 9, 2013 Posted May 9, 2013 Pearly Gates or Alnico II PRO Bridge, Older Wax Label, color does not matter but it must be Standard Spacing and 4 conductor. I also need a Neck Pup, I'm looking for either a Neck Pup from a Phantom Custom or a Lil59 in black (Old Style with the wrapped bobbins).
MCChris Posted May 9, 2013 Posted May 9, 2013 I have a couple stacked Duncan singles I got from murkat that I'm not using, if something like that interests you.
hamerhead Posted May 9, 2013 Posted May 9, 2013 I have 2 bridge PGs (don't know the difference but you've seen pics of them before, zebra), the black Custom(?) that you sent with the Standard, and a zebra bridge Manlius Fat Diane, if any of those would work.
bubs_42 Posted May 9, 2013 Author Posted May 9, 2013 I have a couple stacked Duncan singles I got from murkat that I'm not using, if something like that interests you.With or without the flange?I have 2 bridge PGs (don't know the difference but you've seen pics of them before, zebra), the black Custom(?) that you sent with the Standard, and a zebra bridge Manlius Fat Diane, if any of those would work.Um, if I remember correctly one of them had a Wax Covered Label. What i'm looking for is the same label that the Custom has on it.I'd use the Custom but the Balance between the Single and the Humbering in a Phantom/Proto setup is very important. IMHO I nailed the PhatCat/Duncan Single in my first Build and should go with that again but I want to change it up a little.
MCChris Posted May 9, 2013 Posted May 9, 2013 With or without the flange?Without, I believe, but I'll confirm when I get home.
hamerhead Posted May 9, 2013 Posted May 9, 2013 Got one (a PG that is). It's not perfect (the 'Seymour Duncan' looks rubbed a bit, but the plastic is OK), but I'll send it if you want.What's the difference between it and the other?
bubs_42 Posted May 9, 2013 Author Posted May 9, 2013 The difference is only when they were made and the process in which they were made. I have had a ton of SD's I just seem to gravitate to that particular time period.
FrankieIII Posted May 9, 2013 Posted May 9, 2013 Would this work for you?http://www.ebay.com/itm/Seymour-Duncan-SLASH-APH-2b-Alnico-II-Pro-Bridge-Humbucker-Guitar-Pickup-/261210882028?pt=Guitar_Accessories&hash=item3cd161bfec
bubs_42 Posted May 9, 2013 Author Posted May 9, 2013 Thanks Frankie but no. I do not like the tweaks the Seymour and Slash did to the bridge pup.
