stripped fine tuner socket
Nathan of Brainfertilizer Fame
6 answers to this question
2 ways;
1: Tap and Die and hope the thread isn't too worn
or
2: Helicoil
V-Coil is a cheaper brand than Helicoil and is very good :)
Failing these methods, you will have to replace the tremolo. I'd go route 2 to be sure but 1 is good ;)
2 ways;
or
2: Helicoil
Any hints on how to figure out which size I need to purchase?
Pull out the screw and go to a big box hardware store's nut and bolt department. They often have a set of screw holes mounted somewhere that allows you to figure out what thread pattern you have and what size screw or bolt you have.
If you are lucky, you might have a "nut and bolt" business in your area. "Nut and bolt" or "screw and bolt" is how you will look up their phone listing. They can help you and offer some advice in person.
This ^^^ I'd guess a 3mm thread but a hardware store will be more accurate and will also know the actual thread taper information :)
