Hamer Miller guitar questions
Backlinemark
Hello.
I've kinda been offered a Miller Hamer 6 a side headstock (gold back sides/ red front/ white logo). Been used and front colour has faded. But neck feels ok.
It doesn't have a case- what case should it be in/ will it fit.
Is there anything I should be looking for?
What kind of price do they usually go for?
Thanks for your help.
Mark
10 answers to this question
The non-form fitting Standard/Blitz case will work.
With case in nice condition, they can fetch @$2k, but the range is all over the place below that. I've seen one for $900 on the (very!)low side within the last 4-5 years, but most tend to be around the $1,500 and up area.
These are GREAT guitars. Not gimmicky like the Dean Busch or Bud pieces of garbage. The Hamer Miller and MGDs are built to the same high standards as any Hamer Sunburst, etc.
Sorry- just want to double check- is the case you mean the same one that LostArt/ Vintage lists as
"20. Hamer Standard Case- NOS Hamer case for the Standard and Standard custom will probably also fit Gibson explorer and other similarly shaped guitars."
or should I try and get a red coloured inside one that’s more period correct?
You will have a tough time finding a red lined case, certainly for under $200-$250. The Millers were also at the mid-'80s transition to the black lined cases. If you can find one that isn't form fit on the inside, that'll work (large, open body space). Honestly, the case doesn't matter that much as long as you can get one that fits properly!
The non-form fitting Standard/Blitz case will work.With case in nice condition, they can fetch @$2k, but the range is all over the place below that. I've seen one for $900 on the (very!)low side within the last 4-5 years, but most tend to be around the $1,500 and up area.
Man, don't talk prices! You are killing great deals. B)
Oops!
Sorry. They never sell for more than $350.
The front colour fade seriously reduces the value, at least by a third, compared to an example in good condition.
Yep-cases were black lined.
