I have a Pignose Piggy-in-a-box which has two outputs:
1- "Speaker OUT" (5W power amp)
2- "Pre-amp OUT".
I always use the pre-amp output, but I tried the speaker output recently with a small cabinet and loved the sound I got.
So, I purchased a Hughes & Kettner Red Box Pro, which I intend to use as a cabinet simulator with the Pignose power amp output.
The problem is that this red box needs you to connect a true cabinet or a "load resistor" to its "through" hole, or else your power amp might burn, according to the manual. In other words, the red box doesn't seem to provide the required load to your power amp, so you still have to lead its power elsewhere.
My idea is building a little box with a pair of headphones inside and plug it to the 5w output signal coming from the "through" hole. That would be my "load resistor", but I wonder anyway if there's some risk in doing this.
Is there anyone here able to explain me what would be the right way to proceed?
Thanks a lot in advance!
PS: I'm still using the pre-amp out of the Pignose with my Tech21 Power Engine 60 as a monitor. Both outputs on the Pignose work in parallel; which is great, as I intend to send the red box signal to the PA, while keeping my old configuration for monitoring.
zorrow
Hi there!
2- "Pre-amp OUT".
5 answers to this question
