Okay, boy do I ever need help from the experts on this one! I really am about to tear my fn' hair out at this point.
I recently purchased a great Standard Custom here on the board, but am in the process (I thought) of swapping out the Duncan '59s for some Wolfetone Marshallheads.
Okay great. I unsolder the bridge pickup, and use the old "fishing line" method to be able to draw the new bridge pickup's lead down into the control cavity.
All goes well, and I then move to the neck pickup. I unsolder the lead, and again use the fishing line to be able to draw the new pickup's lead into the control cavity...
Not so fast apparently. As I try to pull the original lead I hit major resistance. Hmm. Okay, I go gently back and forth a bit but I end up pulling harder and harder, having no idea what the resistance might be. At one point I'm really pulling hard. Not smart, I know. Anyway, at one point I see that there is now a bare wire poking out of the housing for the BRIDGE pickup. I'm working on the neck pickup. I really don't know what is in that damn route, but I'm pushing wires out of the way apparently.
As I pull further I see that this wire is SOLDERED to the neck's lead (two conductor), so I unsolder it. Still no idea what that is, a ground wire maybe?
At any rate, I finally get the neck pickup out and attach the fishing line to the new neck pickup. At this point, it seems that whatever is in the channel leading back to the control cavity WILL NOT let the new lead back in. It's ridiculous. I have no idea why, but I can pull with a ton of force, but the new lead will not seem to be pulled into the control cavity.
I have a feeling that I've probably messed up some of the wiring coming from the toggle switch at this point, but I won't know that till the damn lead can be hooked up in the control cavity.
I thought this would be a simple pickup swap as I've done to numerous Les Pauls and Explorer-type guitars. What in blazes am I doing wrong? Can anyone give me some guidance here? Thanks in advance for any assistance or information you can offer!
Navigator
11 answers to this question
