So I bought this channel switcher off of the bay from Buzz Electrics. Basicly it is a two loop and a channel switcher. 1 loop is on the clean and one loop is the drive channel. Fuctionally the pedal works and below is the last communication as of this morning with the builder. Can someone translate this a little more for me?
Hi Shawn,
The pedal is wired to only engage one loop at a time as it is a clean/dirty switcher, so the footswitch will toggle between the pedals in each of the loops when it is pressed. The channel switch will switch at the same time - the channel switch works by shorting the tip of the cable connected to ground so you will need to use a mono cable or a stereo to mono y splitter cable if you would like to choose the switching channel.
Let me know if you have any other questions,
Thanks,
Simon
On Sat, Oct 5, 2013 at 10:51 PM, Shawn Soens <bubs_42@yahoo.com> wrote:
Sorry I have taken so long to get back to you. Yes, I have it routed in the correct direction. And I set it up with a delay in each loop. Plugged the Amps switcher into the channel switch jack. I have the amp on the overdrive channel and the polarity set with the Red Light on. The pedal on that channel works. Then I step on the switch and I have no sound. But if I crank the effect up I can heard a faint effect sound. If I flip the polarity switch I will have the Clean Channel but no overdrive channel. The switcher itself is working I believe, both loops produce sound but only one at a time. It has to be the fact that my amp runs with a Negative Center Channel Switching Cord. It only messes up went I try to switch channels.
bubs_42
13 answers to this question
