metal toggle switch cover need for Standard
Guys the toggle cover is missing off my Ex-zebra Standard, so does anyone have one they can spare?
Thanks
Roy
I just have plastic ones Roy. Have you contacted Hamer?
They are closed till the 16th, so I thought I'd see if there was one here.
The cover should be plastic for '84 IIRC. I'm pretty sure that the aluminum ones were a later addition (the 75-81 ones were I know).
so the plastic one is correct and the metal control is the newer or changed part?? Hell tha makes things easy if that's the case.
Plastic until the later versions from the 90's. It wasn't worth tooling up for a part that was not used much.
