You absolutely need a direct box if you are going to be playing acoustic professionally. If it is just a coffee shop gig on the patio for free food, then don't bother. A Direct box allows you to run a BALANCED line to the P.A. Balanced lines avoid electromagnetic interference. I work with acoustic musicians all of the time professionally as a sound man. I have a trusty radial direct box that I break out whenever they don't bring one. The more well prepared and veteran musicians bring their own direct boxes, the amateurs show up with their instrument and an unbalanced guitar cable. The sound quality is a HUUUUUGE difference.
I wouldn't even consider playing acoustically without a direct box, you can use a simple passive one to fit your needs, they aren't that expensive.
I mean, walk up to a P.A. system with your unbalanced cable and plug it straight in to a channel... you will hear a shitty, small and noisy signal. Plug it into a direct box and voila, you have a bright and punchy signal that will sound great.
A direct box would still be needed when plugging in an electric guitar to a P.A. an acoustic would be no different.
You should be able to try out some direct boxes at your local gear store, just don't try them out on a weekend, music stores are usually slammed on the weekend but are virtually empty through the school hours during the weekdays. Good luck /emoticons/default_smile.png
