How to accurately cut a humbucker sized hole in a Strat Pickguard?
BadgerDave
I have an SSS configured Strat pickguard that I want to modify to fit a humbucking bridge pickup. I won't be using a mounting ring, so the cut-out has to be very clean and accurate. I've attempted this previously using a coping saw and was not happy with the results. I'm a bit "challenged when it comes to maintaining a straight line and even worse at sawing around a corner.
So, is there a technique that i haven't thought of that will ensure a close-to-perfect result? I have a good assortment of tools, including a Dremel, files, Xacto saws and such, but no router or templates.
Ideas?
10 answers to this question
I know I would court disaster if I even tried it - I'd take the easy way out and get a fresh scratchplate.
Yeah - its the cowards way out I know! :lol:
Cheers,
Ben.
Emphasis on "patience." Remember, it's easier to dremel off some more pickguard material than to put some back. :lol:
My partsocaster tele has a three-layer tele pickguard that was too thick to fit under the fretboard tongue of the 22-fret tele neck without shimming the neck.
I hate shimming necks (travesty IMHO) so I cut the guard to wrap around the fretboard tongue by tracing it and then dremeling freehand and VERY SLOW. I cut and re-cut and re-cut, barely taking off material and test-fitting repeatedly. It came out good.
template, dremel, rout bit, bump collar (bearing), dremel router stand.
Dremel, 1/4" sanding drum, patience.
I just found a metal pickup ring in my parts drawer. I'm going to go for it with the 1/4" drum and the pickup ring taped down on the pickguard as a "safety barrier".
Wish me luck!
Thanks to all for the advice.
