I should probably ask this question starting at the VERY basic level, as I really don't have ANY knowledge of passive guitar circuitry, or what capacitors do (or don't do) in a passive circuit. I'm also curious to find out if maybe adding or subtracting something from a guitar's volume and tone circuit will make a less-than-stellar pickup sound better in a guitar, allowing the original pickup to be kept in place. I really don't have the fundage to play 'musical pickups' in a guitar, and a commonly-found pot or capacitor might be more cost effective for me.
For instance, EDITED TO CLARIFY: A SOMETIMES mentioned complaint I've heard here on the HFC is how the stock SD JB pickup on many Hamer USA models is too trebly, bright, or shrill. Will a capacitor, pot or some sort of tone circuit installation cure this, or make it less of an annoyance AND make it sound better? Does anybody out there have any tricks, other than replacing the pickup? Edited to add: Simple Is Better, I'm not looking for something complicated, installation-wise.
Also, a complaint about some 'vintage' guitars are that the pickups don't have much output and power. My stepdad once had a mid '60's Silvertone (made in Chicago, U.S.A.) Harmony hollowbody electric that had very feeble sounding pickups, and he used to have to turn the volume way up on the amp and guitar to make himself heard. Is there any way to increase or optimize the output on a 'vintage' guitar like that, without making pickup changes or using a volume boost?
On the other extreme (and it WAS extreme), my stepdad also had a '80's Peavey electric guitar that had passive pickup Output From Hell...it didn't make the amp overdrive nearly so much as it drove the input but HARD, which made for unpleasant sounding distortion if you tried to play at ANY level from the guitar besides clean. In order to turn up the volume on it beyond a clean (yet loud) level, you had to plug into the second, less attenuated jack. Even then, it didn't solve the problem, the bridge pickup was liveable to use (more or less, again, for clean sounds), but the neck pickup was BOOMY, boomier than some basses that I've played through guitar amps! It was a stock guitar, it wasn't a modded guitar, and it was definitely a passive pickup setup, so what the Hell caused it to do THAT? Just to add, the guitar amp was a old silverface Fender Princeton, and it seemed to do fine with my Hamers, if anything it lacked gain as it was the non-reverb circuit...but the amp and speaker was definitely NOT the problem.
crunchee
TIA!
9 answers to this question
