Jim Fairbairn Posted July 12, 2023 Posted July 12, 2023 One of my tuners on my 1997 Studio is getting extremely difficult to turn. I know they’re Schaller tuners, but what is the exact model I’m looking for and does anyone sell single tuners or do I have to buy all 6? Thanks.
specialk Posted July 12, 2023 Posted July 12, 2023 Maybe put a WTB ad on the For sale board. Someone might have exactly what you're looking for.
crunchee Posted July 12, 2023 Posted July 12, 2023 If you haven't done it already, de-string that particular tuner temporarily and turn the tuner knob in both directions several times (if not more), and see if that does anything.
Dutchman Posted July 18, 2023 Posted July 18, 2023 This^^^^ On 7/12/2023 at 1:11 PM, Dave Scepter said: Lube it!
crunchee Posted July 18, 2023 Posted July 18, 2023 On 7/12/2023 at 1:11 PM, Dave Scepter said: Lube it! 15 hours ago, Dutchman said: This^^^^ So, how does one go about lubing a Schaller M-6 tuner, which is usually the tuner found as stock on a '97 Studio, since it's a sealed/cast housing tuner?
Dave Scepter Posted July 18, 2023 Posted July 18, 2023 3 hours ago, crunchee said: So, how does one go about lubing a Schaller M-6 tuner, which is usually the tuner found as stock on a '97 Studio, since it's a sealed/cast housing tuner? Remove the backplate or squirt Teflon lube down the post shaft
Dutchman Posted July 18, 2023 Posted July 18, 2023 This^^^ Doing it from the top is easiest. Just a couple drops of 3M or gun oil. Remember the tighter you tighten the button the firmer the turning will be. So find the "spot"
Biz Prof Posted July 31, 2023 Posted July 31, 2023 On 7/18/2023 at 5:28 PM, Dave Scepter said: Remove the backplate or squirt Teflon lube down the post shaft On 7/18/2023 at 6:36 PM, Dutchman said: Doing it from the top is easiest. Just a couple drops of 3M or gun oil. Remember the tighter you tighten the button the firmer the turning will be. So find the "spot" Beavis and Butthead would have a field day with these otherwise brilliant pieces of advice.
Jim Fairbairn
8 answers to this question
