Volume boost??
Jeroen
Hey gang,
I am as you might know using a Digitech RP3. I am changing banks for my leads, cause I want to have a delay in my lead sound. Problem I have is that I always have to use my volume pedal on my RP3 for leads and for going back...It remembers its last setting but that doesn't work well for me, cause I often change FX's in a song, like 3 different presets.
My question.
What is a good way to deal with this??? I was maybe another volume pedal or maybe there is something which will give your volume a boost ??
Any ideas are welcome!!
Thanks,
Jeroen
I use a Dunlop Mr Crybaby, it does volume/wah and it has a volume boost on the side via a little red kick switch, it has a knob to adjust the amount of boost. I think it is up to 9db but I can't remember
the only downside is the boost only works on the clean side not on the wah side. so if you are using the boost when you hit the wah you loose your boost. It's one of my fav wahs.
http://www.theguitarhouseonline.com/mypedals/mr%20wahs.JPG
bump
what kinda stuff is out there to boost volume?? I have a Dunlop Crybaby...only the usual model
Jeroen
I set up certain presets in my Rocktron Replifex with a little higher output volume and use those just for lead.
I also recently got a Crybaby Q Zone, which is just a Crybaby wah without the rocker pedal. It's got a volume knob so I can send a little hotter signal to the amp to get some more gain for leads. But the main reason I got it was to add a gentle upper midrange boost when I kick it in. That makes the guitar stand out in the mix during solos without having to drastically raise its volume. Just raising the guitar's volume often actually wrecks the mix.
I use all pedals into a clean tube amp. I keep an RC Booster on all the time and use a Voodoo Labs Sparkle Drive with clean and drive controls at noon for a volume boost. Works great.
If all of your FX are in front of your amp (including your od) and you are just using the amp for clean power.... run a volume pedal before any delay or reverb but after any other effect ... crank the amp to your loudest "boost" level then ease back the volume pedal for your rhythms.....
+1 for the RC Booster...*great* unit. It is very transparent...and with the gain backed off, yields an amazing clean boost that works wonders with the front end of an overdrive section of an amp.
I use the guitar's volume knob. I usually have it around 7 and then for solos I go to 10.
I also use compressor to pound the front end of the amp.
-FunkyE9th
I use my guitars pickups mainly in the middle position, so the 2 Volume knobs are also working as a Tone regulation.
Jeroen
Guest JackButler
I use a Morley Little Alligator volume pedal...there's a knob that can be used to preset the minimum/maximum volume..so for me its used as a solo volume boast and I can solo using any preset patch off my pedal board.
I use two methods.
1. I put a EQ in my fx loop and pretty much just boost the mids a little and put the volume slider just a hair louder than my main signal. That's for a solo boost.
2. I use a tube screamer with only the volume up all the way, tone and drive are on zero, this seems to tighten up the low end for me live. I tried this in the studio and it sounded like crap, in fact I ended up turning my gain on my Boogie 50 cal+ down from 10 to 8.
