Long Shaft Toggle Switches?
tbonesullivan
So, I've got two hamers (special and a newport) that have aftermarket switches, and another that needs a new switch tip, so I figured having a few around would be good. However, I have not been able to find the long switch tip toggle switches anywhere. I checked allparts, parts express, switchcrafts home page, etc etc.
help?
9 answers to this question
help?
it is an exclusive tip for the switchcraft right angle dbl pole switch, like what is used
on a Gibson 1275 dbl neck. part # 12015X
I would contact Kim Keller, See if He could round you up a couple of... maybe...
Here:
www.onlinecomponents.com/switchcraft_12015x.html?p=12318460
Thanks for the info! Now, they don't have standard knurled nuts on the top. What kind of tool do I need to tighten these?
Also, did the hamer newports come with these larger switches, or no? Mine is from 2000 and appears to have a "normal" switch.
hmmm... the switches do in fact look surprisingly like rickenbacker switches.
also, looking at the 12015X, it's a double pole double throw. I just popped the back off my eclipse, which has the correct switch, and it's definitely a single pole single throw.
tbonesullivan
what was your solution?
