Either I haven't noticed this before with other amps, or it's something specific to this amp. Anyway, I was getting a lot of hum on the reverb for the amp. So, I finally got around to cleaning all the tube sockets, all the input outputs, the reverb RCA jacks, etc. I tried swapping out the reverb driver tube. The hum was still there.
I disconnected the reverb cable from the chassis: silence. Then i tried just the cable, not attached to the tank, and there was more hum the closer I got to the tank. Mind you this was with the reverb at around 6, which is LOUD on this amp. I've never had to really crank the reverb. So I plugged it back in, picked up the amp (it's not that heavy) and slowly rotated it, and as expected, the volume of the hum changes, just like with a single coil guitar.
So, is this a bad thing, or just a thing? Is the tank going bad? Should I try grounding the tank? Replacing it? I'm starting to see why some brands encapsulate their reverb tanks in vinyl bags.
EDIT: I just tried swapping out the RCA cable.. no change. Also, I have all my gear running through a Carvin AC120 Power Conditioner. Voltage and Safety ground lights are lit.
tbonesullivan
11 answers to this question
