Summing right and left channels?
hamerhead
I want to combine the left and right channels of my stereo (playback amp) into a single speaker (for mono mixing band recordings).
How do you do that without f***ing something up?
Thanks!
6 answers to this question
Not sure what you're working with but usually you can do that on the mixer.
Thanks!
Stereo what? What is your source, what gear do you have to work with, and what is your desired outcome?
In a DAW? On an analog mixer?
Thanks!
I think you could just do that. L&R are sourcing the same power. Just make sure that both grounds are combined with each other. Other than that it’s fine.
If you mean combining both line level outputs using a simple Wye-cable, that would severely load down each output because they are trying to feed into each other instead of combining through a series/parallel resistive network.  The best case using a simple wye-cable would be a rise in distortion and worst case would be damage to the output circuit of the preamp stage.
Simple/easiest answer is pan everything to one speaker for the mono mix then do the stereo one if you are doing one.
the gain plugin in Logic has a mono button.
