I'm blundering my way towards the home stretch on my first build from scratch, a maple neck-through V for my son who was ten when I started it, is now twelve...
Anyway, it's a flat top and I've been putting on a sapele pommele veneer in bookmatched halves. Thin layer of wood glue, plank and 100lbs of sand overnight to dry. The first half came out great. With the second side, I put on waaaay too much glue and it came out wavy and buckled. I think from just being too wet. I used a heat gun and chisel to strip it off, which worked better than expected. I then hung the guitar on a peg and walked away for a while.
...Nine months later...
I sanded and wood-filled the crappy side, and put in another layer of veneer with much less glue. Still a bit of waviness. I can strip and re-veneer yet again, but would prefer not to. Are there any tricks like steaming or heating that might help shrink the veneer tighter? It's significant enough that I can't sand it level, but not near so bad as the first time, which came out looking like a piece of corrugated cardboard.
Thanks
Edited to add: Don't ask why I've already painted a guitar on which the veneer hasn't been applied. There's simply no reasonable answer.
Toadroller
Some posts about it on my blog here:
http://toadroller.blogspot.com/search/label/HamyV
Thanks
14 answers to this question
