getting rid of smoke smell from a case?
I've had good luck with dryer sheets in the past, now I've got a foam lined SKB that seems to have a neverending supply of cigarette smoke smell. I've left it outside, in and out of the sun, with dryer sheets, I open it up and it's still strong. Any more ideas?, a little talcum powder maybe?
Oh, I think my wife's got some Fabreeze upstairs, I'll try some of that too. My friend has an '80s RoadstarII bass case that smells like someone vominted in it 20 years ago, -that masks any smoke smell very well too. I could just leave one of my toddler daughters diapers in there for a few minutes, that would do the trick!
Ill tell you a trick that when you do it, not only gets out the smell of smoke, but leaves a good fragrance behind.
have you ever noticed the smell of Ibanez cases and SKB cases when they are brand new........Oh GOD I love that smell, nothing like it........except, carmax lip balm....no kidding, smells JUST like it.
Take a couple of these little jars, you know the tiny little whit lip balm jars with the white top?
Put them in your case, close it up and let it sit where it can get nice and hot so it te smell of this balm will permiate (sp) the inside.
Good stuff. Im so addicted to this smell inside my cases that ive done this to brand new cases that didnt stink, they just didnt have that smell........LOVE IT
call me kooky
Is it Carmex?, I remeber those having yellow lids, it must be a different brand then?
yeah....theres a big difference between carmAX and carmEX. dont know what i type have the time, and I dont go back a check it the rest of the time :lol: .............and yes they do have yellow lids, i usually ave quite a few typos in my posts, im sure you'll get used to it :D
I got an eBay guitar in a big heavily padded gig bag that wreaked of smoke. I was going to throw it away after trying everything. I decided I'd stick it up in the attic. I checked it out after letting it hang open for about a year - the thing didn't smell like smoke at all (and still doesn't). Of course, with a hard case it could be the heat separates the tolex from the wood base, but it would be worth a try before throwing it out.
I had from a Duotone a few years back. I fabreezed the hell out of, left it sit open in my garage for a few weeks & then packed it full of dryer sheets - closed for a few months. It got rid of most of it. Also wipe down the out side of the case well.
My 2 cents.
I have an old Peavey amp that smells like it was inside a wet barn for a decade or so. It has a deep musty smell to it. It's currently in the garage, as it literally stinks up the house!
I scrubbed the Tolex with Pine-Sol; the odor is still there. I removed the Tolex, sanded and varnished the wood; the odor is still there. I replaced the speakers and cleaned all the electronics; the odor is STILL there. I give up--maybe it's possessed!
The only way to get really rid of (as opposed to masking) the smoke smell is to get rid of the smoke leftovers.
Carefully without saturating the case, wash it several times with a solution of water, baking soda, and vinegar. This solution works great for dissolving the sticky and tenacious nicotine/smoke residue (you'll see it on the paper towels as you wipe it dry after each washing). Repeat until the towels are not showing any more yellow-green funk.
You may be able to use this solution on the inside of the case also, depending on the material...try a small inconspicuous spot first. It will be necessary to thoroughly rinse out the solution with water, however. If you cant wash it, sprinkle baking soda liberally inside the case, let it sit for a week or so, then vacuum it out. Hopefully the case wasn't left open for months in the presence of smoke, and the interior wont be so bad.
Good luck.
Try Ozium. It's what the use in cars. Any Auto "store" should have it.
Worked for me!
+1000 - Ozium is the shiz! Actually kills bacterial odors and works like no other. I spray it in my fireplace to get rid of the smokey odors that are most obnoxious is the humid, hot, Mid-Atlantic summers....
Worked for me!
+1 Forgot about that one. I did spray down that case with that stuff. be in an open area it some strong $hit.
Worked for me!
I sprayed the insides of the case, closed it up for 4-5 days and when I opened it ,thats ALL I could smell. It disapates after a while but can't smell the smoke anymore.
Worked for me!
When I used Ozium to rid a guitar case of cigarette smoke smell, I did as Fretbuzzbob said. The only thing I did differently was place it in the sun for a day to dissipate the Ozium smell. Worked like a champ.
After Febreeze, drying out, Febreeze and drying again, I left it shut for a day or two, it smells like Febreeze and not so much like smoke. My search is over, -thanks for all the suggestions.
