Auto Experts - cause of steerng tremors?
BadgerDave
2010 Toyota Sienna Minivan. Between 55 and 70 mph it develops a very noticable wobble that I can feel in the steering wheel. Smooth as glass at other speeds.
Possible causes?
Muchas gracias mi hermanos.
20 answers to this question
could have the front end out of alignment. Could also be tire issues, like chopped tires, uneven wear, or even the tires being out of balance because a weight fell off.
Usually this "wobble" is called a "shimmy". Best bet is to take it in and have the tires looked at as well as the alignment.
Front Wheels out of balance.
Could be a couple of weights have dropped off or you hit a pot hole and have put a rim out of shape.
Also could be an egg (a bulge) on a sidewall.
Get your local tyre place to check the balance for you.
T Bone beat me to it by seconds !!
True, but I missed the "check for bulges and dented rims".
Either way, it's something that requires professional help, unless you have an alignment adjuster or tire balancer hanging around. It may just be the tires need to be switched around, aka "rotating" the tires.
+1 to all above. Here's one from way out there...have you had the van on a real muddy road by chance? You could have accumulated mud on the inside of the wheel(s). Had this happen on my wife's car.
Thats a good one, also seen that happen, we could go on, disks, suspension, bushes etc but get the tyre condition and balance checked first as its simple and cheap.
+1 (or is it +2) - anyway, start with the tires; if those are good, keep moving in towards the center of the vehicle (rotors may have picked up debris, bearings may be worn, axle u-joints may be bad, etc.).
Does it happen at double the speed (i.e. 110-140 mph)? :D
Or half the speed? This one may be more reasonable to observe.
At half-speed (or double the speed), the wobble may not be as apparent, but if it's there between 28-35 mph, it's likely tire/wheel/rotor related.
Check the wheel weights. Then swap the front with the rear and see if the vibration disappears or shifts to the back. If it's still there in the front, it just got expensive.
Thanks. I can eliminate the mud, no offroading adventures in the minivan! Tires are new Bridgestone run flats, no visible damage. Hoping it's a wheel balance issue, I'll get it checked on Monday.
I have had the same thing happen with ice/snow caked on the inside of the rim. I would suspect balance first.
If it isn't the tires then I would have someone look at the motor mounts. I had the same thing happen to my Caddy. The description you give is *exactly* what I was experiencing.
I'll attribute it to the advancing age of the driver and his commensurate fear of high speeds.
my car did the same got the wheels balanced and it was sorted just like that
Loose nut behind the wheel? (Sorry, somebody HAD to say it....)
Fixed it.
Took it back to the dealer and traded it for a different vehicle. The cause of the problem will remain a mystery.
I guess that's one way of doing it. A little extreme, but effective.
