Lightest Weight Tuning Machines?
Stike
I have a Mockingbird that's a touch neck heavy with the stock tuners. I ordered a set of the Gotoh Stealths but unfortunately the shaft that the button is on is a wee bit to short for where the holes are drilled on the headstock. Any other ideas?
12 answers to this question
The first Mockingbird I had (back in the 80's, God I wish I still had it) was like that.
My solution was to make a new backplate for the control cavity and a new iinput jack plate out of thick brass sheet which I then had chromed, adds to the guitars weight but sorted the balance problem out a treat and looked pretty cool (in the 80's).
Not much help in your quest for lightweight machine heads I know but it's all I've got.............
Pics will help of course. :)
I thinks sperzels are about the lightest out there, all machined aluminum.
or
maybe bare back waverly's? ($$$)
Would these help? Ebony buttons really helped my Gibson when I exchanged it's heavy "fingers" tailpiece for a trapeze!
Mines the same, I've not worked out how to fix it, but it's not so bad that I can't live with it.
I had a grippy suede strap on it that helped it stay put... That worked.
Murkat nailed my suggestion(s). I'd go with the Sperzels with pearloid/ivoroid/ebony buttons, only because the Waverlys (which are lighter) would just look too "antiquey" on that guitar.
My Mockingbird is neck heavy too, I've thought of having a back control plate made of brass, but just never got around to doing it.
If you want to see if different tuner buttons will help, just take three or four off for a moment to see if it hangs better.
I don't think it'll make enough difference. I'm surprised they don't make the body a tiny bit thicker to make up for it...
Just secure a small weighted item inside of the control cavity to counter balance the neck....
WOW is that purity! True neck thru? Lots of switches n dials, looks like its designed to be paired up with a Mesa MkV.
caddie
