Hamer Duotone body routing....
ghamerinfrance
Just wonder if someone knows how the body route is for a Duotone ?
Does the model sound already like a thinline guitar and can it be used at home without amp or is this really more like a solid body like an Artist with a small chamber ?
Thanks for the info
14 answers to this question
The actual routing would be interesting. No acoustic playing for sure. More like a Newport with piezo acoustic tone option I would expect. It doesn't have a spruce top, does it?
thanks for the info.
Dirk, yes, this is a spruce top apparently :)
The idea is :
Is it like a Newport (almost full chambered) or more like an Artist (small chamber, F_Hole) but I guess the answer is the last one.
At least some had different tops and configurations.....This one is cedar. Sorta the "ultimate" Duotone, I suppose.
A Newport has a solid rear, no metal cavity plate, and is routed from the top side only.
The Artist and Duotone have rear cavities for wiring, and metal back plates.
In the end all have a somewhat similar amount of removed wood, the difference is: it all from the topside or top and bottom.
Lots of guesswork. What's the truth? Would Northfield be willing to testament?
If a more acoustic tone is what you are after with a Duotone, try running a wound G string.
Agreed. The DR Zebra strings worked really well for me. Didn't sound as good on the electric side, but the acoustic side was more realistic.
A good acoustic amp helps a *lot* (Fender Acoustisonic was two thumbs down fer me...) I used an SWR California Blonde with good results. Very good bottom end on that one.
I like the way my Marshall AS50D sounds with my Duotones - both the bullet hole & custom versions. I like the zebra strings with the wound G as well - but be careful - if your nut slot is not big enough to accommodate the wound G it can get stuck and cause tuning nightmares....
Mine's a spruce top. Between the chambering and the oversize control cavity there's a pretty fair amount of wood taken out. Still, it's no Newport in that respect.
I use mine primarily for a beefed-up acoustic sound, although the pure acoustic sounds pretty doggone good if you take the time to tweak it to work with your setup. FWIW I use regular D'Addario 10's with a wound third. The essential ingredient is the wound third on those.
