I'm not terribly familiar with the variety of foundations used in home construction or their associated pros and cons. Can anyone tell me by looking at these photos what sort of questions should be raised about this foundation?
I've only ever lived in homes on slab foundations, and I assume this is some sort of raised, cinder-block construction. My initial concern is the potential for cinder blocks used below ground level (as the grade rises towards the back of the home) absorbing moisture and weakening over time. Am I worrying about nothing or is that a possibility without proper building techniques, and if so, what are the techniques that should have been used?
Should I expect there to be some sort of crawl space access? Any/all advice is needed and greatly appreciated.
The home is located in Southern Mississippi, so the ground will most assuredly always be some level of wet.
cynic
18 answers to this question
