79Sunburst Posted September 5, 2024 Posted September 5, 2024 https://reverb.com/item/80755315?utm_source=android-app&utm_medium=android-share&utm_campaign=listing&utm_content=80755315
Victor (Fret Friend) Posted September 5, 2024 Posted September 5, 2024 That's a lot of money with de-Kahlering of that quality (not great). With a better match/finish maybe but...
DaveL Posted September 5, 2024 Posted September 5, 2024 I am pretty sure I owned that guitar in the 90's. If it's the same one, I think the original ship date was 8/28/81 or 82? I found it for $225 in the Want Advertiser (a print version of craigslist or the recycler in the Boston area) I later sold it for $350... I made bank! not... one of my many stupid moves to come. I despised the kahler so much (it had a wierd black plate to cover the stop tail holes), it just ruined it for me This was a couple years before the HFC. Had I known, I would have gone with a nice veneer with vintage correct curly maple rather than a patch... I remember there was alot of chipping at the headstock where the kahler nut was, I will say it looks alot better than it used to...
79Sunburst Posted September 5, 2024 Author Posted September 5, 2024 If I owned that guitar with all the visible repairs made to it. I would have the fingerboard removed and replace it with an ebony board bound and crowned and simply have it refinished black. Had it never been Kahlered, I wouldn't have done anything at all to it.
kizanski Posted September 5, 2024 Posted September 5, 2024 23 minutes ago, 79Sunburst said: If I owned that guitar with all the visible repairs made to it. I would have the fingerboard removed and replace it with an ebony board bound and crowned and simply have it refinished black. Had it never been Kahlered, I wouldn't have done anything at all to it.
79Sunburst Posted September 5, 2024 Author Posted September 5, 2024 1 hour ago, kizanski said: Woah! Is that yours?
kizanski Posted September 5, 2024 Posted September 5, 2024 2 minutes ago, 79Sunburst said: Woah! Is that yours? It was. Here's some history for you.
79Sunburst Posted September 5, 2024 Author Posted September 5, 2024 4 minutes ago, kizanski said: It was. Here's some history for you. Thanks Kizanski. I like the cut of your jib. It looks fantastic.
Eli Posted September 9, 2024 Posted September 9, 2024 That Kahler repair is so less than great, it makes me want to put a Kahler back on it!
crunchee Posted September 9, 2024 Posted September 9, 2024 Seller is Galaxy Music Company in CA, huh? The asking price is astronomical for sure!
HSB0531 Posted September 10, 2024 Posted September 10, 2024 20 minutes ago, crunchee said: Seller is Galaxy Music Company in CA, huh? The asking price is astronomical for sure! Yep, and for that money they should have first filled in the hole with a billet of mahogany, replaced the entire veneer top, and reshot it in Transparent Red.
HSB0531 Posted September 10, 2024 Posted September 10, 2024 1 hour ago, Joe mama said: what are the other repairs you see? There's another picture on the sellers page with a closeup of the bridge area. You can see the lack of quality work done in that pic. Also: 4-digit Hamer guitars and basses had wider spaced dot markers on the 12th fret. So it could have been either a fretboard replacement, or maybe they ran out of the older fretboards?
cynic Posted September 10, 2024 Posted September 10, 2024 1 hour ago, Eli said: That Kahler repair is so less than great, it makes me want to put a Kahler back on it! 29 minutes ago, HSB0531 said: There's another picture on the sellers page with a closeup of the bridge area. You can see the lack of quality work done in that pic. Also: 4-digit Hamer guitars and basses had wider spaced dot markers on the 12th fret. So it could have been either a fretboard replacement, or maybe they ran out of the older fretboards? Unless it was repaired in the manner requested by the owner, then it’s a perfect repair. Sunbursts also stopped using the wide octave dots after ‘79. I believe it was the same across the brand.
HSB0531 Posted September 10, 2024 Posted September 10, 2024 23 minutes ago, cynic said: Unless it was repaired in the manner requested by the owner, then it’s a perfect repair. Sunbursts also stopped using the wide octave dots after ‘79. I believe it was the same across the brand. I guess the owner or the seller opted for the cheapest repair, and mechanically its a perfectly acceptable repair but: https://reverb.com/item/80755315-hamer-standard-1982-red-4-digit?utm_campaign=listing&utm_content=80755315&utm_medium=android-share&utm_source=android-app this workmanship to me, doesn't warranty a $8,699.00 price tag. I don't know enough about the Sunbursts to say what the timeline was I was only referring to the 4-digit guitars/basses. But yeah they still had the wide spaced dots in 1981 at least: https://www.hamerfanclub.com/forums/attachments/
cmatthes Posted September 10, 2024 Posted September 10, 2024 Take off $2500 for lack of original HSC. That's a mid-2000s case.
HSB0531 Posted September 10, 2024 Posted September 10, 2024 11 hours ago, cmatthes said: Take off $2500 for lack of original HSC. That's a mid-2000s case. And no "USA" after Hamer Lucky for me I still have the original flight case and receipt that says #0531 came from Hamer in a Calzone case.😁 Unluckily for me, #0531 isn't a guitar.
HSB0531 Posted September 10, 2024 Posted September 10, 2024 14 hours ago, crunchee said: Seller is Galaxy Music Company in CA, huh? The asking price is astronomical for sure! Yes it was on the Starship Enterprise and just came back from a 5 year mission. https://www.americanrhetoric.com/MovieSpeeches/startrekintro.html The crew signed the back of the control cover.
Hamerica Posted September 10, 2024 Posted September 10, 2024 16 hours ago, Joe mama said: Does not look like a refinished guitar at all.. How did you come up with that? Good afternoon @Joe mama https://reverb.com/item/73489726-1979-1981-hamer-usa-standard-explorer-flame-top-transparent-cherry-kahler-trem-extremely-rare-original-hamer-case-four-digit-serial-0583 Same guitar last year different dealer with Kahler. @DaveL Interesting, and if so nice recall. I don't believe this guitar was posted prior to last year, however, I could be wrong. I wonder who did the refin? Hamerica
DaveL Posted September 10, 2024 Posted September 10, 2024 46 minutes ago, Hamerica said: Good afternoon @Joe mama https://reverb.com/item/73489726-1979-1981-hamer-usa-standard-explorer-flame-top-transparent-cherry-kahler-trem-extremely-rare-original-hamer-case-four-digit-serial-0583 Same guitar last year different dealer with Kahler. @DaveL Interesting, and if so nice recall. I don't believe this guitar was posted prior to last year, however, I could be wrong. I wonder who did the refin? Hamerica yes, I called into Hamer at the time and spoke to Jim Allen, I remember that date was my wedding anniversary, my first one... lol. at the time, I thought it had what looked like the original case...
bry4321 Posted September 10, 2024 Posted September 10, 2024 I think whenever someone says “that price is outrageous” they should be required to offer something equally cool for a lower price 🤣🤘 It is helpful to see what people think things are worth though to be honest. 😇
crunchee Posted September 11, 2024 Posted September 11, 2024 37 minutes ago, bry4321 said: I think whenever someone says “that price is outrageous” they should be required to offer something equally cool for a lower price 🤣🤘 It is helpful to see what people think things are worth though to be honest. 😇 Tree Fitty works for me, that's the old HFC rule of thumb IIRC.
