Posted (edited)
Cool post Saul, thanks for sharing... I must admit, of all the things that have gone by the wayside, I miss Radio Shack the most... though I know you can buy everything online, there's just something about being able to walk into a brick and mortar with a list to hand pick your components  😪
Edited by Dave Scepter
  • Like 14
Good opportunity for someone.....Go to the current source(s), buy and package a kit of components to sell to those of us that would be starting from scratch.
  • Like 3
  • Thanks 1
I saw that a couple days ago. gonna give it a try. the IC is the only thing I have to order. now back to shoveling snow....
This is awesome. Might be just killer for recording.
  • 2 weeks later...
Definitely.  There used to be a shop on Joppa Rd. near Towson called Baynesville Electronics that was cool.  The folks working there always wanted to know what you were up to if you bought some wire or caps or something.  They went away about 10 years ago now.  Sad.
  • Like 2
  • Sad 1
Our Martin Radio Shack (the larger town in our county that even has a UT "at" school) went out of business around the same time. Absolutely saved my butt when I, on a Saturday, accidentally made contact biasing an amp and blew a couple of resistors. Unbelievable to be able to drive fifteen minutes and grab a couple of replacements rather than wait a week for the mail.
  • Like 5
the chip got here a couple days ago and I started the build but went to an 8 pin socket instead of wiring straight to the chip. got it almost done... last connection... and the socket broke. the little legs are too fragile when not mounted on a PC board.  so, I figured I'd try again and be more careful but the result is the same... broke that sucker trying install the chip. so... solder straight to the chip it is. maybe tomorrow
  • Like 5
Damn, even the $5 Dumble is elusive.
  • Haha 6
2 questions: 1 - Could you mount the fragile socket to a small piece of perfboard, just for reinforcement/support and to prevent soldering to the chip (socket also lets you easily try other chips)? 2 - Could we put a trimmer,or pot, perhaps with a resistor in and out to limit range, in place of the gain resistor?
  • Like 2
My thoughts too. the legs on the 8 pin sockets I had were pretty short. not sure you could get a good solder on whats left. I considered it. if I had another, I would splay out the legs and solder jumper wires to the terminals, then cover them with epoxy. Steel Stick type stuff, like dough when mixed. not liquid that might get in the sockets. and yeah, the 1k replaced with a pot was on my list as well. I'm thinkin 2k. I'll see what I have
as for it being $5.... no. not unless you have leftovers. the chip is $10 to start with. and you don't need to use those 600 volt rated yellow caps either (couple 3 or 4 bucks each)
  • Like 3
  • Thanks 2
Sort of like a tribute to the original, eh? Except he used black silicone goop to cover the tops of the components to discourage reverse engineering... 😂
  • Like 2
  • Haha 3
I'm visiting an old friend on the other side of the country next month and he bought the parts so we can make 2 while I visit. I met him 43 years ago at a first year college electral circuits class. We found out we both liked Y&T, motorcycles and guitars... then started a band! Wish us luck!
  • Like 6
it'll be the most "Dumble" part of the amp...
  • Haha 3
Posted (edited)
speaking for someone in the electronics industry (defense and whatnot)   If anyone needs help lemme know.
I use this site alot.
Www.findchips.com
Edited by DaveL
  • Like 2
Looking forward to the backline photos.  😄
  • Haha 2
